Radial jet with free surface using FIDAP
Old   October 28, 1999, 14:20
Default Radial jet with free surface using FIDAP
Dr. Ahmed Hassaneen
Dear Sir, I just sent a message to J. Horwitz and I will re-send it now to you. My problem is a radial free jet with one free surface. I solved it with S.S. solution (converged in 11 itrs) and RESTART FIDAP to solve with N.R. solution based on the previous run (S.S.) because it was diverging with N.R. as a solver. When I did the RESTART job it has converged with N.R solution in just 2 Itrs. But all of that was at FIXED SURFAC in the PROBLEM definition in both the initial RUN and the RESTART. When I tryed to RESTART FIDAP one more time to solve for the FREE SURFACE (FREE in the PROBLEM definition) the solver abort the job. I continued with it to see waht's in the FDPOST, when I do that FIDAP abort the execution in a one or two second. The only thing I could read before the self termination is somthing about the DATA BASE and no results somthing like that. I'm totally frustrated, do you have any suggestion for me to get out this problem because I think the program should work and should get a solution for the FREE SURFACE as long as the solution of the FIXED SURFACE is there and correct. What do you think? Thanks Ahmed Hassaneen
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 21:13
Free Surface Jet Impingement John FLUENT 0 July 14, 2006 04:45
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 12:57
Re. to my Radial jet with FIDAP and a new question Dr. Ahmed Hassaneen Main CFD Forum 4 November 12, 1999 12:57
Any Body got a Free Surface Solution in FIDAP Dr. Ahmed Hassaneen Main CFD Forum 2 November 8, 1999 15:59
