January 18, 2008, 02:57 |
about Courant number
During calculation, my Courant number was larger than 1, then, is my outcome correct?
what does Courant number really mean? Is it only for watching the stability? What if some of my time step's largest courant number is larger than 1 (or 5 or what)? In what limitation can I believe my solution is good? Many thanks, Daniel |
January 19, 2008, 21:23 |
Re: about Courant number
Courant number is stability as well as accuracy requirement. I order to have accurate solution you should keep it close to unity. Large courant number may improve the stability of simulation but it will be at the cost of accuracy.
Usman |
January 20, 2008, 11:24 |
I also believe that is also deals with convergence, as when my solution starts diverging, lowering your Courant no is a good option..
Please correct me if i am wrong. Thanks, Deepak |
February 2, 2008, 13:47 |
hi, Courant number is responsible for stability of explicit scheme. If, you use implicit scheme then you dont have to think for courant no. But, if it is explicit , then, if it cross 1, your code will diverge....so, always use less courant no. usually 1/4......
February 9, 2008, 01:58 |
Hi there,
thank you all. If my discretization schemes of temporal and convective and viscous terms are implicit, but my pressure terms are explicit. (you know, I am trying to use OpneFOAM). So, 1. do I need to think for courant no.? 2. what do you mean by saying " use less courant no. usually 1/4", are there any references that I can rely on? 3. Again I want to know, whether my result is "correct" once my courant number was larger than one during calculation? 4. What's the relationship between "stable" and "correct"? I mean what if my courant no. is, say 2 or 3, of which you say it is unstable, can i believe my result to be correct? Must I be concerned for stability all the way? Thanks for your patience. And finally, Happy new year to you all. (I 'm from China) Daniel |
Courant number | fireman | FLUENT | 7 | September 11, 2021 11:33 |
IcoFoam unstability, courant number gets large! | vivien | OpenFOAM | 11 | March 9, 2017 03:45 |
LES near wall model & courant number | kasim | CFX | 5 | March 16, 2008 18:23 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Courant number calculation - unsteady flow | Kuba | FLUENT | 0 | November 8, 2005 22:44 |
