January 15, 2008, 07:47 |
interl core 2 duo-quad
Hello.
I am writing my own CFD code in fortran and I have noticed that when it runs on a intel core 2 duo processor, only the 50% of the CPU is used. My question is if I use an intel core 2 quad processor, which percentage of the CPU will be used then. Again 50% or 25%? Therefore, is it better to have an intel core 2 duo at 3 Ghz or an intel core 2 quad processor at 2.4 Ghz? With which processor will I have the best performance. All the other parts (memory, hard disk) are the same for both systems. Thank you in advance |
January 15, 2008, 08:43 |
Re: interl core 2 duo-quad
If u plan to parallelise ur code, then u should opt for a quad core. if not, the best is the machine with more GHz, cuz u will only use one core...
solving a conduction problem in FLUENT using UDF | Avin2407 | Fluent UDF and Scheme Programming | 1 | March 13, 2015 02:02 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Parallel computing quad core | Prad | Main CFD Forum | 13 | February 9, 2009 14:28 |
Questions about CPU's: quad core, dual core, etc. | Tim | FLUENT | 0 | February 26, 2007 14:02 |
Core 2 Duo vc. Dual Core Xeon 3060 | Jan | Main CFD Forum | 6 | February 20, 2007 06:21 |
