January 14, 2008, 20:39 |
non-reflecting boundary condition
Hi
I am solving the Navier-Stokes equation using TVD schemes. I tried using non-reflecting boundary conditions proposed by K.W.Thompson for the far field but the information is still being reflected back. Is there any other options Cheers Shuo |
January 15, 2008, 04:05 |
Re: non-reflecting boundary condition
The Thompson derivation is essentially derived for plane waves normal to the boundary and deviations from this will give reflections. So to minimise reflections one should try to use a circular shaped boundary placed well into the far field with the acoustics sources at the origin.
If your grid does not allow the use of a circular shape a similar effect can be achieved by modifying the boundary conditions for a specified acoustic origin represenatative of the actual sources. At higher computational cost one can introduce an absorbing layer consisting of rows cells beyond the boundary in which a modified form of the Navier-Stokes are solved with a view to absorbing the acoustic motion while presenting the smallest impedance mismatch at the boundary. This is probably the most common approach, particularly for exit boundary conditions, when solving for turbulent flow. |
January 15, 2008, 13:23 |
If you are ready to invest and modify the code you are using then you can treat the characteristics of the flow at the boundary and impose that the fast inflowing characteristics of the flow be zero there. There are plenty of methods, see e.g.
Givoli, D. 1991, Journal of Computational Physics,vol.94, page 1. |
January 16, 2008, 20:30 |
COuld you please provide with a reference for the absorbing layer. Thanks
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
non reflecting boundary condition? | adarsh | Main CFD Forum | 20 | November 10, 2023 02:12 |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 06:05 |
inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 09:56 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 09:28 |
