Open channel (inlet problem)
Old   December 22, 2014, 08:45
Exclamation Open channel (inlet problem)
Burak EKMEKÇİ
burak_ekmekci is on a distinguished road
Hi ;
ı am trying to create a model with using an empty channel and an inlet (water hydrograph). Problem is that ;
- ı must create an inlet that consist of air and water ( two phases) however, water height has to be changed with time respect to mass flow.
I used "open channel" mass flow inlet and pressure outlet.
photos are below.
channel inlet cross section : 0.7 m x 0.7 m
inlet mass flow : 14 l/s
calculated water velocity (in experiment): 0.181 m/s (fluent gives me 0.026 m/s because it distributes all vel at inlet cross sec (0.7x0.7) automatically.
for inlet ;
between time =0 second, t=360 discharge=14 l/s
between t=360, t= 690 d=0.14444(x-360)+14
between t=690, t=1020 d=61.67-0.14444(x-690)
between t=1020, t=1320 d=14
Best regards.
thanx.
burak_ekmekci is offline   Reply With Quote
hydrograph, inlet, open channel, velocity, water depth
simple open channel flow, the inlet and outlet are periodic Sniper OpenFOAM Pre-Processing 31 December 28, 2023 03:12
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
free surface problem with open channel alidogrul Fluent Multiphase 0 August 26, 2013 15:25
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
open channel problem (free surface) Andy Chen FLUENT 4 July 10, 2009 02:20
