How can generate Uniform Cartesian grid?
Old   January 16, 2008, 05:49
Default Re: How can generate Uniform Cartesian grid?
  #21
Harry
Rt, Have you sent me your simple-version code? I guess you miss ed my last message. My email address is s.b.kuang@gmail.com. Thanks for your help. Cheers, Harry
Old   January 17, 2008, 04:50
  #22
BastiL
I am also interested in the changes done for compiling the code with gfortran. I am struggeling with that.
Old   January 17, 2008, 18:40
  #23
marco
For these errors:
1)
IF(FLG_OCTREE) CALL MAKE_REMAINED_LEVELS
1 Error: ELSE IF clause at (1) requires a scalar LOGICAL expression In file CartGen.f90:139 you have to add ".EQ.1" to the if condition, that should be as IF(TRUE) ....
2) DO WHILE(FLG)
1 Error: Exit condition of DO WHILE loop at (1) must be a scalar LOGICAL expression In file CartGen.f90:1298
for this the same as before.
3) delete line 129 and 141 for TIMEF()
4) opening STL file change ACCESS and FORM:
!OPEN(UNIT=1,FILE=FNAME(IFF),ACCESS='DIRECT',FORM= 'BINARY',RECL=2) OPEN(UNIT=1,FILE=FNAME(IFF),ACCESS='STREAM',FORM=' UNFORMATTED',RECL=2)
5) the same for this line:
OPEN(UNIT=1,FILE=FNAME(IFF),ACCESS='STREAM',FORM=' UNFORMATTED',RECL=2) !OPEN(UNIT=1,FILE=FNAME(IFF),ACCESS='DIRECT',FORM= 'BINARY',RECL=2)
6) change line 1707 and 1855 :
!open(unit=ivtk,file=VTKFILE,form='binary',convert ='BIG_ENDIAN') OPEN(unit=ivtk,file=VTKFILE,ACCESS='STREAM',FORM=' UNFORMATTED')
but when I generate the binary VTK file I'm not be able to read it with paraview. I don't know if this is due to this last modification. Reading gfortran documentation CONVERT should be available, but only deleting it I compile the code.
My e-mail is: iota2@libero.it
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
Problems with Turbulence Modeling ezsoal OpenFOAM Running, Solving & CFD 4 November 26, 2009 16:12
FOAM FATAL IO ERRORsimpleFoam hariya03 OpenFOAM Running, Solving & CFD 6 July 16, 2008 09:03
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 19:38
