Operating pressure in cavitation modeling
Old   December 22, 2014, 08:12
Default Operating pressure in cavitation modeling
Tunlu
Tunlu is on a distinguished road
Hi, Everybody
In Flunet, the calculations are performed basing on gauge pressure. Then, for incompressible fluid (for which constant density is set by user), the density is not calculated by using pressure. So, operating pressure is not important for single phase (incompressible) flow as long as Mach number is not very low.
Do you think, when we model cavitation in Fluent, the operating pressure becomes important to be considered although the liquid is imcompressible because it has to compare local static (absolute) pressure to vapor pressure (absolute) to simulate cavitation phenomenon.
Setting operating pressure zero and setting operating pressure 1 atm will results in very different result of cavitation.
In Fluent tutorial for cavitation modeling, the operating pressure is set as zero. But there is no additional explanation about it. Can someone help me to explain it? Thank you so much.
Tunlu is offline   Reply With Quote
Old   June 6, 2017, 18:40
teimur's Avatar
teimur is on a distinguished road
This is also my question, does any body have an opinion or reference about this?
Thanx alot
teimur is offline   Reply With Quote
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
how to incorporate the temperature of fluid in pressure based cavitation model arindamsantra7 Main CFD Forum 0 September 23, 2014 11:46
Saturation pressure in Cavitation svenki7 STAR-CCM+ 1 August 27, 2014 08:27
cavitation model pressure distribution Rahmat Arazgaldy FLUENT 1 May 16, 2012 16:48
Natural Convection (Operating Pressure condition) Andrew Tress FLUENT 1 July 3, 2006 19:27
