DES ( SA+LES) vs DES ( kwSST+LES) for bluff body
Old   January 8, 2008, 10:04
Default DES ( SA+LES) vs DES ( kwSST+LES) for bluff body
Phil
flow separation / vortex shedding.
Does anyone have any experiance with the accuracy of flow separation prediction when using SA for the URANS portion of DES vs. using kw SST for the URANS portion of DES?
My understanding is that the kw SST generally performs well in separation for pure URANS problems.
Does anyone have experience on the separation prediction performance of SA vs kw SST in a DES situation?
I would have guessed that since separation must initiate in the URANS portion of the domain the kw SST model would be preferable?
As it is CFX's DES model which uses kw SST is hopelessly over predicting mu_turb in my low Reynolds number shedding case which is supressing all vortex shedding. I am hence thinking of trying the case with Fluent which gives both options for the URANS portion of the DES model (SA and kw SST).
Thank you.
LES and DES models for wind turbine mohammad Main CFD Forum 6 April 30, 2011 23:01
LES or DES in wind turbine mohammad CFX 2 April 19, 2011 23:16
Spanwise Length and Grid Refinement for SAS-SST, DES, and LES Josh CFX 5 October 14, 2010 20:47
LES simulation of bluff body at Re(d)=1200 arash_nl FLUENT 0 June 1, 2009 14:16
How to use DES well? Daniel Main CFD Forum 0 October 26, 2008 06:59
