Enthaply as calculated by CEA/JANAF Polynomials
Old   December 16, 2014, 11:37
Default Enthaply as calculated by CEA/JANAF Polynomials
major8tom is on a distinguished road
Hello all,
First time posting here, but this problem has been giving me a headache for the last week.
I am using the CEA data base (http://www.grc.nasa.gov/WWW/CEAWeb/) and have written a programme to extract the coefficients for searched species which is all fine. My values for Cp as a function of temperature are coming out fine, however I am struggling with the calculated enthalpy.
Cp/R = a1*T^-2 + a2*T^-1 + a3 + a4*T + a5*T^2 + a6 T^3 + a7T^4
and when I input temperature I get a reasonable value for Cp (calorifically perfect air has a Cp of ~1004 J/kg K this gives 1004.81 at 300K and it varies with temperature) thats great, however:
H/RT = -a1*T^-2 + a2*lnT/T + a3 + a4*T/2 + a5*T^2/3 + a6T^3/4 + a7*T^4/5 + b1/T
gives values for enthalpy which I am struggling to understand. (again using calorifically perfect gas for air as a sanity check, H=Cp*T, therefore at 300K H~=1004*300~=301200 J/kg K)
The above polynomial however gives a value of -2475 J/gk K at 300K.
For Thermally Perfect Gas:
H = integral (T-ref to T) Cp(s) ds + H-ref
H = integral (298.15 to T) Cp(s) ds + H(298.15)
where H(298.15) is the heat of formation (which for air is -4333 J/kg K)
Unfortunately all the documention I can find is quite vague and just says you get enthalpy from the polynomial, however I would like to actually understand the fundamentals if anyone is able to explain it better.
Cheers.
major8tom is offline   Reply With Quote
cea, enthalpy, janaf, polynomial
how to use the 'calculated' boundary condition lg88 OpenFOAM 11 May 9, 2022 11:47
dsmcFoam setup hherbol OpenFOAM Pre-Processing 1 November 19, 2021 02:52
Calculated Boundary Conditions IvyLong OpenFOAM Programming & Development 5 October 18, 2011 00:36
Difference between exact value and calculated value OFU OpenFOAM Post-Processing 2 August 19, 2011 07:10
simple question about calculated bc hyperion OpenFOAM 0 August 14, 2010 15:05
