TVD scheme
Old   January 7, 2008, 02:15
Default TVD scheme
shuo
In the upwind TVD scheme(Yee 87) there's an expression that reads
gamma = 0.5*Psi(a_(i+1/2, j))*(g_(i+1, j) - g_(i, j))/alpha_(i+1/2, j)
a is the eigenvalues of the Jacobian matrix A
g , alpha and gamma(?) are both column vectors
i.e. g = transpose(g00, g10, g20, g30)
So if you break it down to column matrix elements does it become:
gamma00 = 0.5*Psi(a00_(i+1/2, j))*(g00_(i+1, j) - g00_(i, j))/alpha00_(i+1/2, j)gamma00
gamma10 = 0.5*Psi(a11_(i+1/2, j))*(g10_(i+1, j) - g10_(i, j))/alpha10_(i+1/2, j) etc...
Is this correct?
Thanks SHuo
TVD scheme in unstructured finite volume discretization abcdef123 Main CFD Forum 2 January 16, 2013 01:26
Conservative TVD or WENO scheme? Wen Long Main CFD Forum 3 July 9, 2004 17:40
TVD SCHEME explanation h.jordi Main CFD Forum 3 February 28, 2002 12:58
level set method with TVD scheme? zhanglei Main CFD Forum 1 April 25, 2000 15:01
TVD scheme at low Mach number Axel Rohde Main CFD Forum 5 August 6, 1999 03:01
