December 13, 2014, 07:00 |
Really lost! Vortex Panel Method
Rep Power: 12 |
Hey! I'm asked to compute the pressure coefficient distributions ܿfor the upper and lower surfaces of a NACA0012 airfoil based on the experimental data provided, which is the one I'm attaching in the image. Then, I have to calculate the lift coefficient distributions ܿand the airfoil global lift coefficient. The truth is, I'm absolutely clueless on how to reproduce the Vortex Panel Method in MATLAB or any other software (no java-applets or 3rd party apps are allowed), and that's why I'm asking you guys at least for some advice or if you know how to struct this program in MATLAB code or something similar. I'm not asking for a super-program, just the very basics, as I'm clueless and even don't know how to start. The speed is 15.3 m/s.
The data I have is the measure of the pressure in 20 static ports, decalated from the upper and lower parts of the airfoil, as you can see in the image, the angle of attack, lift, drag, pitching moment and rho. Could you help me? That'd be really appreciated! THANKS VERY MUCH in advance!!!! Last edited by reynolds_master; December 13, 2014 at 07:06. Reason: Forgot the image attachment |
Implementing vortex method for generating inlet conditions in LES | cfdonline2mohsen | OpenFOAM Pre-Processing | 4 | September 18, 2022 14:48 |
Vortex Particle Method | eddykendo | OpenFOAM Programming & Development | 0 | June 23, 2014 02:14 |
does vortex panel method satisfy no-penetration boundary condition? | rogerliu | Main CFD Forum | 1 | December 3, 2012 05:40 |
help 3D panel method | luca | Main CFD Forum | 0 | June 22, 2004 05:16 |
Panel method problem | niavarani | Main CFD Forum | 1 | June 17, 2003 11:01 |
