Airfoil Analysis (Lift coefficiet)
Old   December 23, 2007, 02:07
Default Airfoil Analysis (Lift coefficiet)
Alex
Hi, currently I am using CFD to analysis on an airfoil. And my question is about finding the spot for drag coefficient.
Here is what I did, I selected the forces under the report drop down menu. In there, I obtained drag coefficient by using the vector component. Once I have specified it, the forces as well as some other coefficients will be listed on the window. so here is my question; could someone please tell me which column and row indicates the drag coefficient.
Thank you so much.
Old   December 23, 2007, 02:08
Default Re: Airfoil Analysis (Lift coefficiet)
Alex
sorry, the title should be written as drag coefficient
Old   December 26, 2007, 11:19
ag
You might get more response if you provide enough information to actually answer your question. For example, which tool are you using?
Multi-element airfoil analysis CFD Rookie Main CFD Forum 12 November 17, 2016 07:07
Airfoil Analysis (drag coefficiet) Alex FLUENT 3 December 24, 2007 17:14
Airfoil Mesh for DES Analysis - y+ Value asd Main CFD Forum 1 May 3, 2007 11:13
y+ for Airfoil Analysis asd Main CFD Forum 3 April 18, 2007 11:54
High lift analysis using overset kei-tee Main CFD Forum 0 April 10, 2003 10:53
