December 21, 2007, 03:37 |
Fanno Rayleigh flow in pipes
Just a thought, but can commerical CFD solvers be used to model Fanno / Rayleigh flows? Fanno flow requires a friction factor to be exact, so is it possible to consider a friction factor in the solver, or is it accounted for in the turbulence model? Can Rayleigh flow be turbulent? Rayleigh flow neglects friction, but CFD solver apply wall laws, thus creating friction or is that a different 'type' of friction? Any thoughts? |
October 17, 2016, 15:46 |
meenu
Rep Power: 10 |
hi dave,
i just had done a test simulation on rayleigh flow in fluent. I used invisid model with heat source,and results from simulation matched perfectly with reyleigh invisd relation. Mach number increase from 0.3 to 1. Next i am going to run it with turbulence model. Let see what happen......! |
October 18, 2016, 12:07 |
#3 | |
Rep Power: 12 |
Yeah, both can be done.
August 1, 2021, 04:51 |
Tamil Nadu
Rep Power: 5 |
Can you explain more detaily the process?
August 1, 2021, 04:52 |
#5 | |
Tamil Nadu
Rep Power: 5 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 02:10 |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Annular Flow in Pipes | metro | OpenFOAM Running, Solving & CFD | 0 | August 11, 2010 03:34 |
reversed flow at velocity inlet / mass flow inlet | ib | FLUENT | 1 | March 26, 2007 13:11 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
