outlet static pressure of a duct flow
Old   December 17, 2007, 10:24
Default outlet static pressure of a duct flow
anhalimi
Dear all,
Shld the outlet static pressure for a duct flow be zero?
Old   December 17, 2007, 10:27
Default Re: outlet static pressure of a duct flow
ag
Only if you are flowing into a vacuum, or you have chosen a non-dimensionalization that results in zero non-dimensional pressure at that value of exit pressure.
Old   December 17, 2007, 14:11
Barry
I have a similar question about the pressure BC. For an incompressible flow, can I arbitrarily set a static pressure value for the pressure outlet? Does the value I set affect the modelling result?
Regards,
Barry
Old   December 18, 2007, 04:38
Mayur
What is ur inlet condition? If it is vel. inlet then value of static pr. for incomp. flow will not have any effect on the flow(except for pr. values)
Old   December 18, 2007, 06:07
anhalimi
You mean taking the taking the absolute pressure as 0? as in just measuring the gauge pressure? or am i understanding this wrong
Old   December 18, 2007, 09:59
ag
If you are computing gage pressure then zero may be a valid value. Then your nondimensionalization would look something like
p_non = (p - p_baseline)/p_ref
where p_ref is the pressure used to non-dimensionalize the pressure variables and p_baseline is whatever baseline pressure you are computing gage pressure relative to. But absolute static pressure should not be zero, unless as noted above you are expanding into a perfect vacuum.
Old   December 19, 2007, 01:32
Barry
Could you please explain why the value of static pr. for incomp. flow will not have any effect on the flow if using velocity inlet BC?
Thanks,
Barry
Old   December 19, 2007, 07:28
Mayur
Is simple... for incomp. flows pr. enters the equation as only delta P ... so whatever be the absolute value the diffenence will remain the same and flow velocity will decide the pressure gradient... plz go through the analytical soultion of a pipe flow for a laminar case.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Static pressure boundary condition at outlet jennz CFX 4 February 11, 2014 04:29
Guessing the static pressure needed to produce flow rate jpo FLUENT 0 June 22, 2009 13:53
Static Pressure Calculation for Mass Flow Rate Amit Roghs CFX 1 June 16, 2008 22:51
Static pressure at outlet - Stupid question??? Miry CFX 0 September 16, 2007 19:14
