Flow past a cylinder
Old   October 25, 1999, 15:13
Default Flow past a cylinder
ckl
I am now using PHOENICS to solve for the pressure and velocity of an ideal flow past a cylinder. I tried to use body-fitted coordinate system but the result coming out is completely out. In the Cartesian coordinate system, I manage to solve it. I am novice in BFC and PHOENICS, I need some advice from you all. Thanks
Old   October 27, 1999, 06:25
Default Re: Flow past a cylinder
N. Wei
Is the flow inviscid and two-dimensional ? If this is true, I can give you a small program which can deal with this problem.
Old   October 27, 1999, 13:36
clifford bradford
to get specific advice on using Phoenics it is probably better to ask colleagues/coworkers who use it or to use your customer service (if you have that available to you)
2D modelling of flow past a rotating cylinder pds24 Main CFD Forum 1 August 21, 2015 11:50
CFD help: flow past cylinder harsha00711 Main CFD Forum 1 December 24, 2010 22:19
Flow past cylinder harry FLUENT 0 May 29, 2006 07:18
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 07:17
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
