November 25, 2014, 04:54 |
Viscous Dissipation or Similar
Hello Everyone
I am new here, so I hope I have put this in the right area, I also hope that I have asked this question on the right website/forum altogether. I am currently studying in my spare time (just by myself, not through an institution) about heat transfer of fluids when they are shaken, I understand this is called "Viscous Dissipation". Essentially I am trying to find a fluid that, when shaken heats rapidly. I am going down the Viscous Dissipation route as I am looking for this to occur again and again when the fluid is shaken. Rather than an initial reaction, happening only once. I don't have too much knowledge with Viscous Dissipation, but I would assume that there are different rates for different fluids? I am open to ideas here. I have posted on a lot of other forums and I have not heard from anyone, so I am hoping that someone here may be able to help. Is there a specific 'class' or fluids that I should be concentrating on? Any ideas would be much appreciated. Cheers, Mike |
November 25, 2014, 06:49 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
looking at the equations you will see the term in the kinetic energy and thermal energy. It depends on the molecular viscosity of the fluid as well as on the square of the velocity gradient. Therefore, even for the same fluid the dissipation depends on the regime of motion. |
calculating the viscous stress tensor tau for viscous dissipation heating | dgadensg | OpenFOAM Programming & Development | 5 | January 17, 2023 16:20 |
compressibleInterFoam incl. viscous dissipation heating | vigges | OpenFOAM Programming & Development | 5 | June 10, 2018 07:06 |
Viscous forces (interDyMFoam) differ between OF 2.0 and later versions | maxof | OpenFOAM Running, Solving & CFD | 2 | May 30, 2013 05:17 |
how to calculate the viscous dissipation rate for a turbulent pipe flow | Yakamoz | Main CFD Forum | 1 | June 16, 2012 14:35 |
TKE SPECTRUM & DISSIPATION | Christian Paukert | Main CFD Forum | 2 | March 14, 2001 20:34 |
