why do we need Reynolds number for wind tunnel? |
November 22, 2014, 04:23 |
Nicolas Guo
Rep Power: 11 |
you know, when we use the wind tunnel, we first should know its Running Mach number and Reynolds number, which are used to compare the experimental data and real data of flight. But i do not know which property the Reynolds number influence eventually, the turbulence intensity or viscosity ? |
November 23, 2014, 06:08 |
Rep Power: 16 |
The Reynolds number compares the mass effects of the flow to the friction effects of the flow. Because of scaling you are not be able to reproduce the same RE in the wind tunnel so you need to check the RE in the wind tunnel, so that the main flow phenomena around your body are the same.
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 92 | May 21, 2024 08:56 |
[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext | miladrakhsha | OpenFOAM Community Contributions | 106 | July 3, 2023 11:26 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
Applications of Reynolds Number | Nadeem99 | Main CFD Forum | 0 | December 10, 2012 03:10 |
