Unsteady solver + MRF (=frozen rotor) approach
Old   November 21, 2014, 19:13
Default Unsteady solver + MRF (=frozen rotor) approach
xxxxx
xxxx is on a distinguished road
Dear all,
concerning turbomachinery applications, I would like to know from you if you ever heard about an unsteady PISO based solver used to solve a MRF case.
Since I was experiencing troubles with a steady SIMPLE MRF solver, I wrote my own transient-PISO-MRF solver and found it was a good solution (probably because of PISO solver instead of SIMPLE), both in terms of numerical convergence and, subsequently, of engineering results (torque, energy,flow field,..). I would like to understand if there is anything new in the proposed approach or if it's something already known.
Thanks a lot.
Federico
xxxx is offline   Reply With Quote
Old   November 24, 2014, 17:09
xxxxx
No answers here?...
Federico
Old   November 29, 2014, 05:02
Nima Samkhaniani
nimasam is on a distinguished road
well , i guess once i read in FLUENT help that its not quite right to use MRF method for transient process, but Fluent has the same option too , but it recommends to use dynamic mesh approach for transient process
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   November 29, 2014, 05:15
crixman's Avatar
Christian
crixman is on a distinguished road
Dear Federico,
yes I heard of it here:
http://www.training.prace-ri.eu/uplo...ugal_pumps.pdf
I was also interesting in the topic and wanted to compile it, I was wondering if you could share the code for testing.
If you are interesting in another alternative I compiled an MRFpUCoupledSolver which has been already tested with promising results, and I could share it if you want
http://www.cfd-online.com/Forums/ope...rames-mrf.html
Let me know!
crixman is offline   Reply With Quote
Old   November 29, 2014, 13:05
xxxxx
Dear nimasam,
of course a steady-state approach is not the right choice for a rigorous transient study. That was not my goal.
Dear crixman,
I don't know what you mean for pUCoupled. I mainly work on OF2.1.1 by OpenCFD, not the extended version. Can you please give me some more info? What's the purpose of that solver?
In my opinion it's very easy to compile that solver, just pick the lines you're interested (in this case, those where you recall the MRFZones and add the centrifugal and Corriolis sources) from MRF and paste into the pimpleFoam.
Anyway, if you want I can give you the source code.
Lamps!
Federico
Federico
Old   November 29, 2014, 15:12
crixman's Avatar
Christian
Dear Federico,
pUCoupledFoam is available in foam-extend 3.1 - the goal is to have a strong p-U coupling in order to reduce the number of iterations required by the SIMPLE algorithm to reach convergence.
It seems to be a promising solver for steady-state simulations.
If you could share the code would be great, I would save some time - and I can share MRFpUCoupledFoam so you can have a look at the algorithm! If you want I can send you my email in private.
Let me know!
Old   December 1, 2014, 16:56
xxxxx
Ok I can send it to you.
Let me know how (email, else,..)
Federico
Old   December 2, 2014, 10:34
crixman's Avatar
Christian
ok I sent you a private message- let me know!
convergence of density-based solver for unsteady flow zhengjg FLUENT 0 June 16, 2014 11:16
Problem with implicit unsteady solver CCMuser STAR-CCM+ 2 March 3, 2010 12:20
2D Unsteady Potential Flow Solver A.S. Main CFD Forum 2 November 16, 2005 04:38
nUMECA UNSTEADY SOLVER dimitris Main CFD Forum 1 May 16, 2001 11:28
Matlab Unsteady 1D Euler Solver??? Johan Sylwander Main CFD Forum 1 May 24, 2000 16:26
