Wave generation
Old   November 30, 2007, 16:54
Default Wave generation
Dan
Does anyone have experience creating water waves? I want to look at waves striking a dock piling.
I started by writing a function to vary the water height at my inlet using a simple sine function, the wave doesn't propogate downstream however, instead it reverses back on itself and after awhile disappears
Old   December 1, 2007, 12:52
Default Re: Wave generation
andy
You need to specify more than a displacement as an initial condition for travelling waves. A left moving wave and right moving wave may well have the same shape (displacement) at an instant in time but they will have different particle velocities.By (presumably) specifying a zero particle velocity you have not specified any overall movement of mechanical energy in one direction or the other (think force*velocity). Often this will give you equal right and left moving waves (i.e. drop pebble in water) but if you are doing this at the boundary then your boundary conditions may well interfere.
need tutorial files(Simulation of Wave Generation in a Tank) gholamghar FLUENT 45 May 6, 2018 11:57
Looking for UDF files of the tutorial "Simulation of Wave Generation in a Tank" seucj Fluent UDF and Scheme Programming 12 August 21, 2015 06:52
Wave generation The_Architect FLUENT 3 August 16, 2011 04:39
Wave generation using open channel wave boundary condition krishnaprasad Main CFD Forum 0 March 3, 2011 22:28
need tutorial files(Simulation of Wave Generation in a Tank) gholamghar FLUENT 0 March 28, 2009 04:08
