November 20, 2007, 01:35 |
axisymmtric numerical model
I am getting convergence problem for axisymmetric numerical model for a simple pipe flow problem. the boundary conditions i have used are as follows
at x=0 u=1,v=0 delp/delx=0 delpdash/dx=0 at x=l delu/del/x=0, delv/delx=0 p=0 pdash=0 at r=0 delu/delr=0 v=o delp/dy=0 delpdash/dy=0 at r=R wall can some one tell, how this ll differ from the code of rectengular co-ordinate. Now i m trying with changing the area of the face and voulme of the cell and rest all the code is same. Thank you in advance. |
November 20, 2007, 09:52 |
Re: axisymmtric numerical model
What is pdash?
You should be solving momentum equations for u and v plus a continuity constraint on the solution that determines the pressure distribution (to within a constant - it's the pressure gradient that matters). |
November 20, 2007, 14:27 |
Thank you OTD for the reply.
Pdash is the correction in the pressure. I am doing the same solving the continuity and u,v momentum equation in collocated grid using predictor-corrector pressure correction algorithm.. my question was how it differs from the algorithm for cartesian co-ordinate system. Now for axisymmetric the change i have done is in the area and volume of the cell. is there anything more other that..... |
New implemented algebraic Reynolds stress model | volker | OpenFOAM | 13 | October 21, 2013 01:01 |
Wrong calculation of nut in the kOmegaSST turbulence model | FelixL | OpenFOAM Bugs | 27 | March 27, 2012 10:02 |
species transport model or mixture model? | achaokaoyan | Main CFD Forum | 0 | July 10, 2010 11:52 |
Problems bout CFD model of biomass gasification, Downdraft gasifier | wanglong | FLUENT | 2 | November 26, 2009 00:27 |
Feasiblity of CFD model for Real-Time applications | la mimi | Main CFD Forum | 2 | January 28, 2007 05:49 |
