Error: Divergence detected in AMG solver: temperature ? |
November 7, 2014, 22:10 |
Sankeerth
Rep Power: 11 |
Please help me out! Iam doing a CFD modelling of Vortex tube in Fluent. Iam a beginner to CFD. Regards, Sankeerth |
November 8, 2014, 09:58 |
hi
rahul kumar
Rep Power: 12 |
what type of help you need? what you want to know about cfd?
November 11, 2014, 03:45 |
Sankeerth
Rep Power: 11 |
Iam doing a project in Vortex Tube. I want to model the flow. To do that how should the mesh be?(any advice on this would really be good) And how do i mesh manually in Ansys Mesh. Iam using Workbench Interface for solving in Fluent.
Any help in this regard is much appreciated. Thank you in advance |
November 11, 2014, 04:06 |
#4 | |
Sankeerth
Rep Power: 11 |
and At outlets i have considered that gauge pressures are zero. |
November 11, 2014, 05:48 |
hi
rahul kumar
Rep Power: 12 |
just decrease your under relaxation factor and then try again
March 13, 2015, 11:27 |
Sankeerth
Rep Power: 11 |
Iam not able to generate the temperature difference no matter how many times i try. I tried simulating in Solidworks and Fluent , was completely unsuccessful in my attempt to obtain results.
Can anyone please what might be the reason for this? |
March 13, 2015, 12:29 |
Matt
Rep Power: 18 |
You probably have a mesh issue if you are a beginner. That can cause all kinds of issues. You really aren't giving us enough information to help you. What does your mesh look like? What kind of turbulence model are you using? What are your initial conditions? These are all things that you should try to communicate when you ask for help.
March 13, 2015, 14:30 |
Sankeerth
Rep Power: 11 |
Dimensions of the model:
Inlet Dia: 4mm Vortex Tube Dia= 2.5mm Cold tube dia = 0.84mm Length of Vortex tube= 125mm Model: Standard k-e Turbuence model Solver type: Steady, Pressure based Fluid: Air(Ideal gas) Boundary Conditions: Inlet Pressure= 601325 Pa Outlet Pressure Cold = 101325 Pa Outlet Pressure Hot = 101325 Pa Operating Conditions Pressure= 0 Pa Turbulent Parameters: Turbulent Intensity= 10% Hydraulic Diameters at each Cross-section have been given as input in Hybrid Initialization has been done Meshing Details Sizing: On proximity and curvature Initially assembly meshing was not at all used but i found very poor quality of elements were being formed, then i tried with assembly meshing there was good increase in quality Assembly Meshing(Cutcell) has been done to improve element quality Attached is the mesh image can initialization of the model influence the convergence ability? How do we modify the mesh if it's not proper(I mean should we go by trial and error only)? |
March 13, 2015, 14:43 |
#9 |
Matt
Rep Power: 18 |
Is this your whole domain? Can you show a cut through the middle that shows what the mesh looks like inside? Unfortunately, it is tough to tell much from looking at the outside surfaces.
March 13, 2015, 14:50 |
#10 |
Matt
Rep Power: 18 |
There are several ways to check if your mesh is adequate. The most important being y+, but also quality, skewness, volume change and aspect ratio. Ask someone in the Fluent forum how to proceed with that if you are unsure. I use different software so I can't really help you on that. This isn't really the right forum for such a discussion anyway.
http://www.cfd-online.com/Forums/fluent/ |
March 13, 2015, 22:40 |
#12 |
Sankeerth
Rep Power: 11 |
Other Mesh images are attached here
Is this mesh fine? If not how do you suggest i mesh the part? |
March 16, 2015, 08:03 |
#13 |
Matt
Rep Power: 18 |
Is this gray thig a fluid or a solid? I am confused. You should be meshing the fluid around your object, not the object itself. Unless you are solving for heat transfer, then you will need the solids too.
As for wall Y+, check the wiki on this site for details. It is a fundamental aspect of CFD and if you are ignoring it you are in for all kinds of trouble. Basically it is a measure of how appropriate your boundary layer mesh is for the local flow conditions. There is more to it than that, but you should really figure that out for yourself. I use star-ccm+. |
March 16, 2015, 08:27 |
#14 |
Sankeerth
Rep Power: 11 |
The Gray thing is the fluid volume extracted from the solid model(solid model has been made in solidworks).
The meshed & extracted fluid volume has been shown in the pictures |
March 16, 2015, 08:35 |
#15 |
Matt
Rep Power: 18 |
In that case it looks like you need to add bounday layer refinement. I would bet that is why you are seeing divergence. Your cells near the wall are too big for the near wall calculations (i.e. your y+ is too big). I am not sure what options your software has available so I would HIGHLY recommend going and getting help in the Fluent forum (link posted above).
Error: Divergence detected in AMG solver: pressure correction | wanna88 | FLUENT | 19 | April 6, 2016 02:57 |
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature | bubuchacha | FLUENT | 6 | February 26, 2013 03:30 |
Divergence detected AMG solver error | Rub Nawaz Khalid | FLUENT | 2 | August 14, 2010 11:01 |
" Divergence detected in AMG solver: temperature" | Suman | FLUENT | 4 | September 11, 2009 09:31 |
Error: divergence detected in AMG solver | Yash | FLUENT | 2 | December 2, 2008 10:12 |
