Difficulty when using gmsh to create a structured mesh.
Old   November 4, 2014, 08:06
Default Difficulty when using gmsh to create a structured mesh.
Al Prinn
Apron is on a distinguished road
Hi!
I am trying to create a structured 3D mesh from an annular duct, using gmsh. I begin by creating a 2D mesh. I would then like to extrude the mesh to create the 3D mesh, but it is at this stage that the problems occur... Below is my .geo:
// element spacing
Nz = 50; //136
innerh = Pi/2*0.13/10;
outerh = Pi/2*0.424/10;
// centre point
Point(1) = { 0, 0, 0.4};
// inner circle points
Point(2) = { 0.13, 0, 0.4, innerh};
Point(3) = { 0, 0.13, 0.4, innerh};
Point(4) = { -0.13, 0, 0.4, innerh};
Point(5) = { 0, -0.13, 0.4, innerh};
// outer circle points
Point(6) = { 0.424, 0, 0.4, outerh};
Point(7) = { 0, 0.424, 0.4, outerh};
Point(8) = {-0.424, 0, 0.4, outerh};
Point(9) = { 0, -0.424, 0.4, outerh};
// lines
Line(1) = {2, 6};
Line(2) = {8, 4};
Transfinite Line{1, 2} = (0.424-0.13)/0.01;
// circle arcs
Circle(3) = {2, 1, 4};
Circle(4) = {4, 1, 2};
Circle(5) = {6, 1, 8};
Circle(6) = {8, 1, 6};
// surfaces
Line Loop(10) = {1, 5, 2, -3};
Plane Surface(10) = {10};
Transfinite Surface{10};
Recombine Surface {10};
Line Loop(11) = {1, -6, 2, 4};
Plane Surface(11) = {11};
Transfinite Surface{11};
Recombine Surface {11};
// extrusions
// Extrude{0,0,-0.2}{Surface{10}; Layers{Nz*0.2}; Recombine;}
Extrude{0,0,-0.2}{Surface{11}; Layers{Nz*0.2}; Recombine;}
This gives me a strange dislocated geometry, but I am not sure why. If I comment the last line, and uncomment the second last, then the bottom half of the duct disappears.. Can anyone see my error?
Cheers,
Al
Apron is offline   Reply With Quote
gmsh cylinder, structured hex mesh
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[Gmsh] Structured mesh in gmsh without Extrude function ericnutsch OpenFOAM Meshing & Mesh Conversion 2 December 6, 2013 08:52
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
