November 2, 2014, 03:36 |
Questions regarding flow around a cylinder
jaegak lee
Why does laminar separation occurs at 80~90 degrees from stagnation point in circular cylinder? But not over 90?
November 8, 2014, 04:51 |
kiyoung kim
Rep Power: 12 |
we can not predict exactly where the separation occurs. however we know that separation occurs at the adverse pressure gradient region. In inviscid vade, adverse pressure gradient starts from 90 degrees. In viscois flow, however, adverse pressure gradient starts before the 90 degrees owing to wall stress. The separation angle will be delay if free stream velocity increases but it is almost 90 degrees when larminar separation occurs. transition begins after that.
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Running a feedback control simulation of the flow around a cylinder | gasagna | OpenFOAM Running, Solving & CFD | 0 | July 16, 2014 11:03 |
flow around a cylinder | pXYZ | Main CFD Forum | 14 | July 25, 2011 11:05 |
flow around circular cylinder...plz help | yousef | FLUENT | 4 | March 28, 2006 12:01 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
