November 7, 2007, 06:31 |
Dissipation local Isotropy Kolmogorov Idea
Hi
According to Kolmogorov idea(1941) of local isotropy , since dissipation occurs at smallest scale we have: epsi (ij) =2/3 epsi * Kronokor delta (ij) dissipation occures at small scales and it is logical to accept that isotoropy is valid at that scales and e(11)=e(22) =e(33) but the thing that is not clear for me is that why the other terms are zero , for instance why we don't have disspiation for uv (e12) . what does it have to do with isotropy and the concep of invariancy. I would be thankful if anyone can help me to clear this doubt. |
November 7, 2007, 13:40 |
Re: Dissipation local Isotropy Kolmogorov Idea
Kronecker
November 7, 2007, 15:41 |
The Kronecker symbol d_ij is, as I recall, the only isotropic second-order tensor (other than the zero tensor). More precisely, d_ij is the rectangular cartesian component representation of the unique (to within a scalar multiplier) isotropic second-order tensor. The isotropy is manifested in its action on vectors, i.e. its dot product with vectors. Its action preserves the direction of the vector upon which it acts.
If, v_i is the cartesian component representation of an arbitrary vector v, then the isotropy can be seen from either the component representation d_ij*v_i = v_j, or from the matrix-vector representation I*V = V. In the latter, I is the identity matrix, V is the column vector representation of v, and the "*" is matrix multiplication (which implements the dot product). The component representation of the isotropic second-order tensor in general coordinates is g_ij or g^ij or d^i_j, i.e., the metric tensor. As far as I recall, there are no non-zero isotropic tensors of odd order (at least this is true for vectors, which are order one), and there is more than one isotropic tensor of order four and higher (even) order, but my memory could be faulty. In addition to the Kronecker deltas, the permutation symbols are also involved somehow. Isotropic tensors are important in expressing tensorial invariants. The book by Heinbockel, which used to be available as a free download, probably has more details. |
November 9, 2007, 16:52 |
I guess I forgot to explicitly answer your question as to why the off-diagonal terms are zero. The reason is that you happen to be dealing with rectangular Cartesian coordinates. Notice that in general oblique coordinates the covariant components of the metric tensor, namely the g_ij, are non-zero for all i and j. In rectangular Cartesians, g_ij reduces to d_ij with off-diagonal terms being zero. Also, in general oblique coordinates, the mixed contravariant-covariant representation of the metric tensor, namely d^i_j, again has zero for its off-diagonal terms, owing to the orthonormality of the coordinate (covariant) basis vectors relative to the dual (contravariant) basis vectors. g^ij, g_ij, d^i_j, and I are all representations of one and the same isotropic second-order tensor, if I did not make myself clear earlier.
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 08:36 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
