November 6, 2007, 17:42 |
2-D validation
Hi
I am trying to validate a 2D compressible solver. I have used the shock reflection problem and is considering using a boundary layer normal interaction problem from Schlicting(?). I want to use one more validation case but the thing is the domain has to be rectangular (that would exclude the forward step problem right?). Any ideas? Shuo |
November 7, 2007, 12:45 |
Re: 2-D validation
How about the sod cylindrical example? You can see it in the book titled 'Riemann Solvers and Numerical Methods for Fluid dynamics' written by E.F.Toro. That example is included in chapter 17. I also used this example to test my code.
November 7, 2007, 13:56 |
Re: 2-D validation
If you are going for time accuracy you should at a bare minimum run a shock tube with a moving shock. Make sure you can satisfy the jump conditions and the shock speed. Another good case is a convecting vortex - you can use the results to get a good handle on how dissipative your algorithm is.
Validation test for 2d euler equations in subsonic regime with canonical squares | panou | Main CFD Forum | 2 | August 24, 2011 16:21 |
Validation of Star CCM+ | iand | Siemens | 2 | December 8, 2010 07:59 |
Validation cases | GGerber | OpenFOAM | 7 | October 30, 2010 05:11 |
Oscillating flow around cylinder validation error | Zak | FLUENT | 0 | September 22, 2005 17:09 |
Urgent: RAE 2822 validation | NID | Main CFD Forum | 0 | September 3, 2004 11:34 |
