Microparticle in fluid flow modeling
Old   November 5, 2007, 18:46
Default Microparticle in fluid flow modeling
Rajat
I'm trying to model a microfluidic device that has miroparticles flowing in it with water. I'm using CFD-ACE GUI but I don't know which module to use for this. Any help would be greatly appreciated.
Old   November 8, 2007, 05:39
Default Re: Microparticle in fluid flow modeling
Jim
It depends on what you are trying to do. When I did something similar (low RE mixing in a MEMS device), I used the Chemistry module to define the particle distribution as a simple scalar. This made it easier for me to do all the rheology stuff I was interested in (variations in viscosity, density, diffusivity etc). I could of used the User Scalar module, only this wasn't compatible with the free surface flow module I needed for my work (you don't mention an air/water interface so you may not have this problem). FYI, the user scalar module allows for anisotropic diffusion whereas the chemistry module doesn't. If you want to go for full-on particle tracking, then you need the Spray module.
Old   November 12, 2007, 13:28
Rajat
I'm trying to use the Spray module but I'm not sure how to use it. I just have particles in water flowing though a channel and I want to see their flow pattern.
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant flow rate through a small area inside the fluid domain. robingilbert OpenFOAM 7 October 4, 2010 17:19
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 17:29
Modeling of free surface in CFD ? Kim TaeMin Main CFD Forum 18 July 16, 2001 12:38
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
