October 29, 2014, 04:38 |
Prove Boundary layer has Vorticity
How do you prove that boundary layer has Vorticity?
October 29, 2014, 09:15 |
Filippo Maria Denaro
Rep Power: 73 |
October 30, 2014, 04:13 |
adrin
Rep Power: 17 |
To be careful/precise - and food for thought - it is not sufficient to suggest that du/dy is part of vorticity and hence there is vorticity in the boundary layer. The other component of vorticity is dv/dx. How do you know that the two components don't cancel each other out?
So, a more rigorous response based on math or physics is necessary! Assume the wall is stationary, so the wall velocity is zero everywhere. This means dv/dx is zero _at_ the wall. Since there is free stream velocity, u_inf, and u_wall = 0, we have (only) du/dy _at_ the wall (assuming 2D). So, there is vorticity (generation) _at_ the wall, which then diffuses away from the wall and convects in the boundary layer. If the flow is incompressible, the wall is the only source of vorticity generation. adrin |
October 30, 2014, 04:34 |
#4 | |
Rep Power: 73 |
October 30, 2014, 04:54 |
adrin
Rep Power: 17 |
My explanation was based on the origin of vorticity (at the wall) and its evolution due to diffusion and convection, and it leaves no room for "what if" - except if the wall moves or there's flow through. One can also provide order-of-magnitude justification.
Having said that, v does vary with x in the boundary layer (when it's not fully developed yet, though very small) adrin adrin |
boundary layer, thoery, vorticity |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
[snappyHexMesh] SnappyHexMesh: Layer on corners | Pj. | OpenFOAM Meshing & Mesh Conversion | 9 | July 17, 2014 04:26 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
