Problem in cavity flow problem
Old   October 30, 2007, 03:57
Default Problem in cavity flow problem
saad
Dear Friends i am simulating cavity flow at Re=5000 and above. i am facing problem of plotting the small teritory vortex of the streamfunction at the bottom right corner , Although my result and other vortces looks similar to the results availabel. I am using tecplot. what should i do???. some one told me that you need to do some special treatment to your formulation at the bottom line, which i am not sure.
Also what shoud be the best boundary condition for pressure to get good convergence. i am using artifical compressibilty method.
Thanks a lot
Old   October 30, 2007, 23:04
Default Re: Problem in cavity flow problem
Soheyl
I guess you need to refine the mesh. With finer mesh, you can get Tecplot to show the corner streamlines.
Old   October 31, 2007, 16:46
otd
He doesn't give mesh numbers, so it could certainly be a problem of inadequate resolution in the corners.
Also, even if the resolution is adequate, the stream function values in the corners are small relative to the big eddy in the center of the cavity. Tecplot needs to be told to produce lines for small contour levels.
Old   November 1, 2007, 01:16
Saad
""Tecplot needs to be told to produce lines for small contour levels.""
How can i do it? however, I used from 129x129 t0 512x512, but fail to draw the small vortex. Intersetingly, when i used u,v to plot vector field, i get samll votex at the corner, looking for, but the figure not looking good.
Old   November 1, 2007, 08:45
otd
I haven't had access to Tecplot for several years (too expensive!), but I do recall being able to set levels for the contour lines that are actually displayed on the screen.
Your resolution certainly seems good!
Initial &Boundary conditions for pressure in cavity flow problem with SIMPLE approach Mehdi-Sanaei Main CFD Forum 0 May 7, 2011 05:02
Flow not moving - Supersonic/Initial Pressure problem? shankara.2 FLUENT 0 June 9, 2009 21:49
Multiphase flow problem icedou FLUENT 6 July 10, 2005 03:52
Problem with increasing Re no. for cavity flow Quarkz Main CFD Forum 3 July 2, 2005 17:58
turbulent flow in cavity problem using k-w model khairy Main CFD Forum 3 February 27, 2005 13:12
