October 28, 2007, 08:17 |
CFL for explicit hypersonic problem
Hi, How do I determine the CFL number for an explicit hypersonic problem? Is there any book or paper?
Thanks, Subramani |
October 28, 2007, 18:24 |
Re: CFL for explicit hypersonic problem
CFL number (Courant-Friedrich-Levy). For discretized transport problems, the CFL number determines how many mesh cells, a fluid element passes during a time step. Or rather, the fraction of a time step to pass one cell. For compressible flow, the definition is different. Here, the CFL number determines how many cells are passed by a propagating perturbation. Hence, the wave-speed, i.e. fluid speed plus the sound speed, is employed. For explicit time stepping schemes, such as Runge-Kutta, the CFL number must be less than the stability limit for the actual scheme to converge. For implicit and semi-implicit schemes, the CFL limit does not constitute a stability limit. On the other hand, the range of parameters in which these schemes converge may often be characterized by the CFL number.
Alfonso Medina, OpenFlower Manual Good Lick |
October 29, 2007, 13:19 |
Thanks a lot. I am running a steady state problem in FLUENT. Say, my Mach number is 2 and temperature is 227.81 K and grid spacing of 1e-6 m then dt=dx/(a*(M+1))=1.1e-9 This is my dt and do I need to multiply this by a factor of 0.9 to get the CFL number?
Thanks, Subramani |
conduction problem | venkataramana | OpenFOAM | 3 | December 1, 2013 07:30 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
Problem of mass conservation in multispecies flow in porous media and T° gradient | pilou | FLUENT | 0 | January 31, 2011 08:19 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 05:29 |
Hypersonic problem | Subramani Sockalingam | Main CFD Forum | 0 | October 28, 2007 09:20 |
