Cant run in parallel on two nodes using OpenMPI
Old   October 26, 2007, 10:54
Default Cant run in parallel on two nodes using OpenMPI
CHristofer
Hi!
I have recently converted two computers to Ubuntu and installed openFOAM 1.4.1 on ecah of them. I can run parallel on each node(2 cpus) but get following message when trying to run host/slave using 4cpus for a case:
Executing: /home/a403518/OpenFOAM/OpenFOAM-1.4.1/.bashrc Executing: /home/a403518/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/ensightFoam/bashrc Executing: /home/a403518/OpenFOAM/OpenFOAM-1.4.1/.OpenFOAM-1.4.1/apps/paraview/bashrc a403518@ENEPCST75:~$ mpirun --hostfile machines simpleFoam $HOME VAFAB -parallela403518@enepcst84.af.se's password: [ENEPCST75:11188] [0,0,0] ORTE_ERROR_LOG: Data unpack had inadequate space in file dss/dss_unpack.c at line 90 [ENEPCST75:11188] [0,0,0] ORTE_ERROR_LOG: Data unpack had inadequate space in file gpr_replica_cmd_processor.c at line 361 [ENEPCST75:11188] [0,0,0] ORTE_ERROR_LOG: Data unpack had inadequate space in file dss/dss_unpack.c at line 90 [ENEPCST75:11188] [0,0,0] ORTE_ERROR_LOG: Data unpack had inadequate space in file gpr_replica_cmd_processor.c at line 361 [ENEPCST75:11188] [0,0,0] ORTE_ERROR_LOG: Data unpack had inadequate space in file dss/dss_unpack.c at line 90 [ENEPCST75:11188] [0,0,0] ORTE_ERROR_LOG: Data unpack had inadequate space in file gpr_replica_cmd_processor.c at line 361
It seem that the host finds the slave and I enter the password for the slave, then this message follows...
Do I need the specific case to be copied to both nodes and do I need to start OpenFOAM on the slave before executing the mpirun command. Please help me!!
//Christofer
Parallel run of OpenFOAM in linux and windows side by side m2montazari OpenFOAM Running, Solving & CFD 5 June 24, 2011 04:26
parallel run for fsi simulation??? smn CFX 2 July 19, 2009 05:04
Problem on Parallel Run Setup Hamidur Rahman CFX 0 September 23, 2007 18:11
Minimum number of nodes to run CFX in parallel Rui CFX 3 April 11, 2005 21:46
How to run parallel in ICEM_CFD? Kiddo Main CFD Forum 2 January 24, 2005 09:53
