Inputs for porous zones in FLUENT
Old   August 31, 1998, 08:05
Default Inputs for porous zones in FLUENT
Roel van Os
Hello CFD collegues
I am recently involved in modeling and oil platform, using the FLUENT code. To speed up calculating time, I modeled the regions on the platform, which contain many pipes, as boxes. By defining those boxes as porous zones, I try to simulate the right pressure loss due to the pipes.
My problem is that I do not know the right inputs for the permeability and the resistance factor. I do know about the Blake-Kozeny equation, but that one is valid only for porous zones, which model packed beds.
If anybody knows how to calculate the permeability and resistance factor inside a porous region, consisting of pipes, then please let me know. (Or if you know some literature dealing about this subject).
Thanks in advance, Roel
Old   September 1, 1998, 13:41
Default Re: Inputs for porous zones in FLUENT
Rasputin
I'm sure Idelchik put pipe bundles in a wind tunnel to determine loss coefficients, he's certainly considered every other type of obstruction! Look at:
'Flow Resistances - A guide for Engineers'
Erwin Fried
I. E. Idelchick
ISBN 0-89116-435-9
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 20:12
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 12:55
Problem with fluent fluind inputs bahadir FLUENT 0 April 18, 2011 11:25
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 13:56
