unstructured grid
Old   October 10, 2014, 13:55
Default unstructured grid
mojijoon is on a distinguished road
Hi ,I've been working on a problem regarding incompressible flow in a truncated cone shape like channel and I've used an unstructured grid for this problem.
Also there is a draft note by Jayathi Y. Murthy on the net which I've been using for equations for simple algorithm .
My question is (if you had read that draft note) should I consider any changes in equations in that note?
mojijoon is offline   Reply With Quote
fvm, simple algorithm, unstructured
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
2D airfoil simulation, turbulence, boundary layer, unstructured grid louis.langouche@gmail.com FLUENT 0 March 3, 2010 09:19
unstructured grid using Gridgen prapanj Pointwise & Gridgen 5 May 1, 2008 00:49
Unstructured grid approach Li Yang Main CFD Forum 8 June 11, 2003 11:48
Unstructured grid finite volume methods Marcus Main CFD Forum 3 December 5, 2000 01:25
