October 10, 2014, 11:02 |
Can I use flux limiter for scalar in DNS
SAM
Rep Power: 14 |
Dears
I am doing Direct Numerical simulation at high Pr numbers. I have question regarding the advection of scalar. Can I use flux limiter; like Koren limiter; for scalar? I have to say that If I don't use the limiter, the scalar gives strange number which are out of bounds? Thanks |
October 10, 2014, 11:20 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
In DNS you should have such a fine grid to resolve all physical wavenumbers of your fields. Therefore, you should be able to solve your problem without any limiter. What is more, using a limiter it should not produce relevant effect if the relevant small scales are well resolved. However, if you are solving a pure advection of scalar, that is Df/Dt=0, using a sharp discontinuities then no grid exists that ensures the absence of oscillation (apart the case of first order scheme) and a limiter is necessary for numerical reasons. |
Ultimate Flux Limiter | gentela | Main CFD Forum | 1 | August 2, 2016 20:55 |
3rd-order upwind, flux formulation for limiter | carambula | Main CFD Forum | 6 | September 6, 2011 15:41 |
slope limiter and flux limiter ?? | Ameya J | Main CFD Forum | 1 | June 13, 2011 12:05 |
flux limiter involving tensor : How to use fvc::flux() with volTensorField ? | Cyp | OpenFOAM Programming & Development | 2 | January 21, 2011 04:36 |
Lax-Wendroff flux, using any flux limiter | mcaro | Main CFD Forum | 1 | September 30, 2010 11:37 |
