conservation angular momentum swirling flow
Old   October 20, 2007, 12:15
Default conservation angular momentum swirling flow
Roberto
Hi, I am working with CFD to analyze a swirling burner with a square section combustor. When I calculate the angular and the axial momentum inside the combustor, it decreases the more I check downstream to the burner exit. Do you know what would create a decrease in the angular and axial momentum inside a square section combustor? Should the swirl number variate inside the combustor?
Thank you very much for your help.
Swirling flow simulations Ugo FLUENT 19 July 16, 2012 16:59
conservation equation for multiphase flow alan81 Main CFD Forum 0 July 5, 2011 15:17
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
problem with 2D swirling flow N.A. Beishuizen Siemens 2 August 20, 2001 09:52
Flow Visualization of impinging swirling flow on the wall. sangaria Main CFD Forum 2 March 26, 1999 14:31
