two phase flow with surface tension
Old   October 20, 2007, 07:58
Default two phase flow with surface tension
qunwuhe@hotmail.com
I have a quesiton on how to define the difficulty for simulation of two phase flows with interface. If the flow is dominated by viscocity, it is simple If it is dominated by inertial, the interface shape changes a lot, it is not difficult the flow dominated by surface tension is the most difficult.
Then the problem is how to define the difficulty. Once there is a parameter named Ohnesorge number Oh= mu/sqrt(D rho sigma), but in there parameter, the diameter is beside the surface tension. As we know according to the Lapalace dp=sigma/r, small r means higher surface tension force.
Does anyone has a better idea?
Old   October 20, 2007, 08:13
Default Re: two phase flow with surface tension
jinwon park
Someone uses the level set method to distinguish the interface. Then the heviside function can be incorporated to determine density and viscosity across the interface.
rho=rho1*H+(1-H)*rho2 vis=vis1*H+(1-H)*vis2
where rho1 is density in phase 1 and rho2 in phase 2. H is a heaviside function ranging from 0 to 1.
Please refer to the immersed interface method, the level set method and so on.
Old   October 21, 2007, 01:29
qunwuhe@hotmail.com
You misunderstand my questions. My questions is to know how difficult the problem is, instead of how to represent the density.
Surface tension driven flow Saeedeh Mohebbinia FLUENT 3 October 11, 2019 13:12
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 20:01
Problem with capturing water-spreading for free surface flow devesh.baghel OpenFOAM 2 December 10, 2009 02:21
how 2 freeze 1 phase flow field & start lagrangian KK CFX 5 February 14, 2008 17:48
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
