October 7, 2014, 03:07 |
Divergence - two phase flow
I am trying to simulate a two phase flow - water and water vapor.
I know the mass flow rates of two phases entering from a single inlet and pressure outlet BC. I did not consider phase change too. I tried simple and PISO , result is same Need some advice |
October 7, 2014, 10:06 |
Michael Prinkey
Rep Power: 25 |
You need to provide a lot more information. What code are you using? What is the dominate phase (water droplets in steam, steam bubbles in water, or both)? What multiphase model are you using? (Eulerian/Eulerian, Eulerian/Lagrangian, slip velocity, VOF)?
October 7, 2014, 22:37 |
Model used: Mutliphase Mixture
Dominant phase if water and it has 20% of water vapor. Considered liquid water as primary phase. |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Two Phase Darcy flow with gravity -> problem | Cyp | OpenFOAM Programming & Development | 0 | November 17, 2010 07:58 |
two phase flow + ice phase and breaking | soeren87 | OpenFOAM Running, Solving & CFD | 0 | September 19, 2010 10:20 |
Validation for laminar Disperse phase flow | shashwat | Main CFD Forum | 0 | April 4, 2008 02:20 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 07:59 |
