Characterization of pressure drop
Old   October 1, 2014, 12:32
Default Characterization of pressure drop
Sylvère RASERA
tchup is on a distinguished road
I tried to search the forum, but I did not find a clear answer to my question :
After a numerical simulation of a turbulent flow (in a quite complex geometry), which parameter do I need to post-process in order to locate the areas contributing the most to the pressure drop (not considering the contribution of the wall) ?
I usually plot the contours of total pressure on a cross section plane, but the conclusion is not obvious.
Can I find an answer checking for exemple the turbulent dissipation rate ?
Thanks in advance !
tchup is offline   Reply With Quote
Old   October 3, 2014, 15:45
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
If you want to characterize the pressure drop then why would you look at anything else rather than the total pressure? If you have a closed geometry such as a pipe you should probably average your total pressure over a cross section.
lovecraft22 is offline   Reply With Quote
Old   October 6, 2014, 10:01
Sylvère RASERA
My problem was that because the flow is very disturbed due to the geometry (it isn't a simple cylindrical pipe), the pressure or total pressure varies a lot across the flow, not necesserily indicating a pressure loss.
But I will try to average the total pressure over a cross section and plot it, maybe it will help me.
Thank you !
cfd, post processing, pressure drop, turbulence
How to plot pressure drop with Periodic BC? bigfans FLUENT 7 November 8, 2016 12:28
Pressure drop using Fan type BC Alexis Sack OpenFOAM Running, Solving & CFD 2 September 22, 2014 10:18
How to study pressure drop of continous phase in VOF model sajeesh FLUENT 4 February 5, 2014 23:01
Pipe Flow - Pressure Drop Daniel L FLOW-3D 2 December 10, 2010 05:23
Pressure Drop at entrance of a rotor-stator. Resnick Main CFD Forum 0 November 20, 2007 15:50
