Rotating Wall Problem for Elastohyrodnamic Lubrication |
September 25, 2014, 15:42 |
Mike
Rep Power: 14 |
I am doing a 2-D simulation of a rotating cylinder near a flat plate. Boundary Conditions: Inlet and outlet is just set to a static pressure of 0Pa. The rotating wall is set to have a velocity of 5rad/sec. All other boundaries are set to no-slip wall. I attached the picture of the problem I am trying to solve with my boundary conditions. I would like to make sure my boundary conditions are correct because I am getting an error in CFX. The error description is below. I am thinking it is because I have a rotating wall attached to another wall (Wall2 and Wall3) and wanted someone to please check this for me. I refined my mesh and was still getting the error below. I attached two pictures of my mesh. The error described that "nodes on a rotating surface might not lie on the surface of revolution" made me think my mesh was wrong. Looking at my up close picture of my mesh, I just wanted some feedback if this was okay. Any insight would be greatly appreciated. | The angle between the specified velocity and the element surface is| | 88.902 degrees at this face. This is considered an error because | | it implies that the mesh is moving. The following are possible | | reasons for the error message: | | 1. There is a setup error; for example, an incorrect axis of | | rotation. | | 2. There may be a meshing problem; for example, the nodes on a | | rotating surface might not lie on the surface of revolution. | | 3. The boundary is curved and the mesh is very coarse. In this | | case, you may modify the tolerance by increasing the | | expert parameter 'tangential vector tolerance wall' | | from its default of 20 degrees. |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 16:33 |
RPI Wall Boiling Problem | aliemadi | CFX | 4 | September 1, 2018 22:14 |
[mesh manipulation] mergeMeshes problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 3 | July 29, 2015 05:15 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 13:11 |
Rotating wall transient signal in CFX | tiguiblais | CFX | 0 | April 23, 2010 15:11 |
