using Surface Evolver to measure the deformation between two 3D shapes
Old   September 24, 2014, 23:26
Default using Surface Evolver to measure the deformation between two 3D shapes
kjc
kjc
kjc is on a distinguished road
Hi all,
I am new to the forums and new to Surface Evolver. I have an application in mind that I am sure is fairly trivial. I have two mesh models of shapes, call them "source" and "target". My hope was that I could register them in R^3 using some other algorithm and then look for the patches where the source shape differs from the target shape. In most cases this will be by some concave or convex patch on the source shape.
I would like to set up some sort of flow that takes the source shape and evolves it to the target shape (mean curvature flow?) and gives me a measure of the energy required to deform the source to the target.
Has anyone used S.E. for an application like this? Assuming that I can translate the meshes to .fe files, does anyone have any recommendations about how to perform the minimization?
Thank you in advance for any feedback!
-kc
kjc is offline   Reply With Quote
Old   September 25, 2014, 19:26
Default additional info on my question
kjc
kjc
I suppose I am basically asking if anyone has used a target shape to impose constraints on the final state of the evolution of another source shape that is a deformed version of the source and that flows from source to target?
Thanks!
Old   September 25, 2014, 19:36
Default constraints
kjc
kjc
Possibly with level set constraints?
Old   July 19, 2019, 07:55
vidyadhar
vidyadhar is on a distinguished road
Originally Posted by kjc View Post
Hi all,
-kc
Hello kjc,
Were you able to succeed in using SurfaceEvolver?
Could you translate meshes to .fe files?
I am also trying to learn surface evolver?
Can you share your experience in translating meshes to .fe files.
Thanks & Regards,
vidyadhar
vidyadhar is offline   Reply With Quote
Old   July 27, 2022, 04:16
Shay
dgshay is on a distinguished road
Hi all,
-kc
Hi, did you find the way to translate the meshes into .fe files?
dgshay is offline   Reply With Quote
deformable mesh, deformation, deformational flow, shape, shape optimization
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 02:44
surface evolver rupam Main CFD Forum 0 March 24, 2013 13:29
[snappyHexMesh] Layers don't fully surround surface EVBUCF OpenFOAM Meshing & Mesh Conversion 14 August 20, 2012 05:31
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 14:43
surface deformation bala Main CFD Forum 2 April 5, 2001 13:08
