KUMAR SAURABH
Rep Power: 12 ![]() |
I discretized an unsteady state convection diffusion equation and solved it with both CDS and upwind scheme and Crank Nicholson time step. But the solution of CDS and upwind are same till certain time interval (exactly speaking till 60 iterations) but after that upwind tends to give wrong solution. Is there something wrong with my code or is it because of less accurate upwind scheme.
Please help. Thanks in advance. |
Roman Gobitz-Pfeifer
Rep Power: 16 ![]() |
I think this is not the right subforum to discuss this. Nevertheless upwind scheme shouldn't be used for 3D problems. To check the discretization error it's recommended to run your simulations with different schemes with increasing order as you did. Different results indicating a discretization error and it's recommended to increase the numer of cells and rerun the simulation. cheers wikie |
Implementation of 2nd order upwind scheme | jaason | OpenFOAM Running, Solving & CFD | 4 | February 6, 2015 17:40 |
Wrong fvm::div assembling | santiagomarquezd | OpenFOAM Bugs | 90 | December 27, 2010 12:54 |
Periodic Boundary Condition for upwind difference | yohey44 | Main CFD Forum | 0 | October 27, 2010 13:10 |
the effect of upwind difference | hades | Main CFD Forum | 8 | March 14, 2009 23:43 |
Central Difference vs Upwind Defference | S. Balasubramanyam | Main CFD Forum | 5 | January 16, 2002 01:58 |
