How to mesh the 1st grid point?
Old   October 7, 2007, 10:44
Default How to mesh the 1st grid point?
Daniel
I am very young to CFD world. I'm trying to use oodles to learn LES techniques. Now I have some problems about meshing.
I saw a paper on flow over a cylinder using Fluent, its meshing guideline is like this, Reynolds Number Flow Regime Yplus/First Cell Height Re < 1000 Laminar First Cell Height = Cylinder Radius/24 1000 < Re < 20000 Turbulent, Enhanced Wall Treatment Yplus < 10 Re > 20000 Turbulent, Standard Wall Functions Yplus > 30
Q-1. Why mesh like this? Is there any references on how-to mesh under LES and DNS? Sorry, I did not find help from <grid generation> and <Fluent Mannual>...
Q-2. Is that mean: If I use wall function, then I can set the 1st grid point at the place of y+=30? If I use not wall function, then I should set the 1st grid point at the place of y+=1?
Q-3. I heard "Laminar LES"=DNS, what does it mean? Is it mean that their mesh is identical?
Q-4. I see that the 1st grid point is decided by the flow state, but When I predict flow around a building on a certain Re for example, the laminar and turbulence coexist around the building, then how to decide the 1st grid point?
Thanks for your time
Daniel
Old   October 8, 2007, 03:27
Default Re: How to mesh the 1st grid point?
Kasper
take a look at this..
http://www.cfd-online.com/Forum/fluent.cgi?read=52743
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 05:49
UDF to define source term at every grid point Ralf Schmidt FLUENT 0 September 21, 2006 12:32
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 11:09
