Reynolds number for simulating with different domain lengths
Old   September 12, 2014, 14:58
Default Reynolds number for simulating with different domain lengths
RS2
RS
RS2 is on a distinguished road
HI.....
I am simulating following flow conditions for air flowing over a flat plate (L=2m):
rho_inf = 1.2 kg/m3
u_inf = 300 m/s
T_inf = 300 k; (viscosity comes out to be = 1.8*10^-5)
Reynolds number this case is Re = rho*u*L/viscosity = 4x10^7.
In simulating above conditions, what Reynolds number should i take for
1)for a domain length of L = 4
2)for a domain length of L = 1
Basically, the aim of question is for flow over large lengths (which are difficult to simulate), we scale down the length in simulations. How the Re will change for different cases?
RS2 is offline   Reply With Quote
Old   September 14, 2014, 05:09
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
I'm not sure I understand your question. First, why would you scale your model? Second, your Re usually depends on the characteristic length of your body, noton your domain…
lovecraft22 is offline   Reply With Quote
Old   September 14, 2014, 06:25
Virendrasingh Pawar
virendra_p is on a distinguished road
If you want to scale your model....you need to maintain Re same over all scales....and the velocities will change accordingly (we do this for pipe flows....i guess you can use it here as well...please check)....calculate Re using L=2 and use it for other two cases...so velocities will change if you keep air as fluid...
virendra_p is offline   Reply With Quote
Old   September 16, 2014, 07:40
RS2
RS
Thankyou for your suggessions...it was helpful.
modelling, reynolds number, scaling
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 17:32
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 13:55
CFX Solver Reynolds Number haider760 CFX 2 March 4, 2012 23:05
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
