4-digit NACA airfoil: Trailing edge of the airfoil is not quite zero
Old   September 10, 2014, 16:55
Default 4-digit NACA airfoil: Trailing edge of the airfoil is not quite zero
sisi is on a distinguished road
Wikipedia says:
Note that in this equation, at (x/c) = 1 (the trailing edge of the airfoil), the thickness is not quite zero. If a zero-thickness trailing edge is required, for example for computational work, one of the coefficients should be modified such that they sum to zero. Modifying the last coefficient (i.e. to −0.1036) will result in the smallest change to the overall shape of the airfoil.
Is that correct? I need a reputable source for that information...
sisi is offline   Reply With Quote
Old   September 14, 2014, 17:06
Julian Langowski
Ruli is on a distinguished road
Dear Sisi,
book recommendation:
Abbot and Doenhoff - Theory of wing sections
There you find (almost) everything on NACA airfoils and also the formulas for contours.
Best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Old   September 20, 2014, 06:07
Thank you for your response. Just borrowed this book. Unfortunately it contains no information on "Modifying the last coefficient"...
Old   September 23, 2014, 10:02
Troy Snyder
tas38 is on a distinguished road
Rather than modify the coefficient of the equation used to generate the profile, you can linearly extrapolate the sharp trailing edge point.
tas38 is offline   Reply With Quote
Old   September 24, 2014, 21:13
Martin Hegedus
Martin Hegedus is on a distinguished road
http://www.pdas.com/naca456.html
Martin Hegedus is offline   Reply With Quote
Old   October 1, 2014, 11:00
Thanks for your replies!
So drawing a straight line from an appropriate point of the upper surface to the last point of the lower surface...? In fact, deleting some points of the upper surface ?
Originally Posted by Martin Hegedus View Post
I checked this page but couldn't find the answer to my question....
http://www.pdas.com/naca456thick4.html
Also note that the trailing edge thickness is NOT zero.
Anyway, I will try using different modified geometries to see which numerical results show good agreement with experimental data ...
[DesignModeler] 3mm Trailing edge radius on closed airfoil henrikdahlberg ANSYS Meshing & Geometry 1 June 10, 2015 06:04
2D FFD Optimization RLangtry SU2 2 August 5, 2014 10:48
Leading edge and trailing edge of an airfoil rotor blade Jun_Milan CFX 0 July 11, 2014 00:07
