DSR
Rep Power: 12 ![]() |
Hi, I am trying to implement a FV pressure-based CFD code with variable density (ideal gas). I am using the algorithm from Ferziger/Peric (pressure correction -> velocity correction & density correction) which seems to be most commonly used (SIMPLEC variation). But has anyone had luck with this algorithm? What validation cases do you use? Thank you for your help!
compressible, density correction, pressure-based |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM Running, Solving & CFD | 17 | December 3, 2014 19:41 |
Using Density Gradient C_R_G(c,t), Pressure Based Solver | Anirudh_Deodhar | Fluent UDF and Scheme Programming | 1 | October 25, 2013 05:43 |
Strange residuals of the Density Based Solver | Pat84 | FLUENT | 0 | October 22, 2012 15:59 |
regarding density and pressure based solver | Reddy | FLUENT | 0 | August 18, 2007 11:11 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
