September 25, 2007, 00:10 |
solve negative volume error
hi, i m regulerly facing a negative volume error in my turbine model which is not allowing the solver to run ........ how can i solve this using pro-amm
September 26, 2007, 22:57 |
Re: solve negative volume error
To solve a problem, first you have to find what causes it? if you agree on that principle, then take a look at your linear algebra book under the heading scalar triple product play a bit with the numbers, see by yourself how negative volumes are produced then you would be able to solve your negative volume problems, this is called experience. Good Luck
polynomial thermophysical properties II | sebastian | OpenFOAM Running, Solving & CFD | 54 | November 21, 2019 08:12 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 08:43 |
blockMesh error ... | balkrishna | OpenFOAM Pre-Processing | 0 | August 17, 2010 03:39 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 15:11 |
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." | sega | OpenFOAM Community Contributions | 12 | February 17, 2010 10:30 |
