How to open .SAT file by GAMBIT?
Old   September 24, 2007, 14:55
Default How to open .SAT file by GAMBIT?
Ertan Taskin
Can I open .SAT file by GAMBIT? Or what I need for that?
Thanks.
Old   September 25, 2007, 03:11
Default Re: How to open .SAT file by GAMBIT?
Kasper
Yes, you can do that. You should adjust the facet resolution in AutoCad if you used it to generate your sat file. Command "facetres".
BR Kasper Skriver, Denmark
Old   September 25, 2007, 09:35
Ertan Taskin
Thanks Kasper
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
Gambit error on linux: Unable to open file ... Wim Heirwegh FLUENT 1 October 10, 2007 12:06
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
