September 2, 2014, 14:32 |
Smoothed Particle Hydrodynamics
Tim
Rep Power: 13 |
I am a bit stuck with some SPH code and hope somebody out there can help... I have generated a geometry consisting of two spherical volumes formed of SPH particles. The spheres are different diameters and I am trying to calculate the curvature of the surface. I know that the curvature should be 1/radius but am not getting this result from my SPH code. I am getting the same curvature for each sphere so am trying to work out what I have messed up:-( I am using the paper by Kelager as a guide - M. Kelager. Lagrangian fluid dynamics using smoothed particle hydrodynamics. Master’s thesis, University of Copenhagen, Department of Computer Science, 2006. image.diku.dk/projects/media/kelager.06.pdf The curvature, k, is defined as the Laplacian of the color field divided by the norm of the gradient of the color field. (Eqn 4.29) For the gradient, I am looping through all neighbour cells and summing mass(j)/density(j) * grad_W * dx/|r| for the X dir gradient mass(j)/density(j) * grad_W * dy/|r| for the Y dir gradient mass(j)/density(j) * grad_W * dz/|r| for the Z dir gradient This looks like it gives the correct answer For the Laplacian of the color field I loop through neighbours and sum mass(j)/density(j) * laplacian_W Do I need to multiply this by something - if so what. It isn't defined in the paper... I am using poly 6 kernel and have coded gradient and Laplacian functions as per the paper. Any advice would be very gratefully received |
Basic and simple SPH-code questions (smoothed particle hydrodynamics) | Peacekeeper | Main CFD Forum | 2 | March 12, 2014 17:29 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 02:30 |
Smoothed Particle Hydrodynamics | Brindaban Ghosh | Main CFD Forum | 0 | September 21, 2001 05:06 |
Smoothed particle hydrodynamics | Lao Liu | Main CFD Forum | 1 | June 13, 2000 01:01 |
Smoothed particle hydrodynamics | amou | Main CFD Forum | 1 | December 10, 1999 05:16 |
