simulation of mixing flow
Old   October 17, 1999, 14:31
Default simulation of mixing flow
willams
Hi, everyone: we want to simulate air mixing flow in a chamber. Two air streams enter the mixing chamber perpendicularly and mix together. we put a static mixer in the mixing chamber to enhance mixing. Is it possible to simulate such complicated flow problem? How can we generate the grid? Any suggestion would be appreciated.
willams
Old   October 17, 1999, 17:21
Default Re: simulation of mixing flow
Shi Xuefeng
Hi, Your problem is not much dificulty. I think the most thing is you should have some soft.
Old   October 17, 1999, 18:29
willams
Thanks for your reply. yes, we can use some commercial software, but I think the challenge is we have a static mixer (maybe not a simple one) in the mixing chamber. I don't know how to generate the grid. How to give the boundary conditions.
willams
Old   October 17, 1999, 21:07
Guosheng Kang
Hello Willams, could you specify the static mixer?
Old   October 17, 1999, 22:37
willam
The static mixer is four triagular tabs with each one fixed at the middle of side walls of mixing chamber.
Willams
Old   October 18, 1999, 00:30
jeruel
wil! is there a thing as a static mixer? me thought mixing is not static
Old   October 18, 1999, 01:46
willams
It means the components of mixer is static, not active.
Help with slug flow simulation. Kes FLUENT 3 November 9, 2019 22:39
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 13:34
calculate volume flow from a 2D simulation SimonH. OpenFOAM 0 October 27, 2009 05:39
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 17:29
simulate a turbulence mixing flow arya FLUENT 0 August 30, 2007 07:08
