Moving meshes: Arbitrary Lagrangian-Eulerian (ALE) formulation
Old   August 29, 2014, 12:03
Default Moving meshes: Arbitrary Lagrangian-Eulerian (ALE) formulation
Joachim
Joachim is on a distinguished road
Hey everyone!
I have a question regarding moving grid algorithms. Let's say I have a working NS code, and I want to implement the ALE formulation to run oscillating airfoils. Please correct me if I am wrong:
1. I modify the convective fluxes only, including the term -Vg*Q everywhere (Q is the state vector and Vg the normal grid velocity at the face). The normal convective flux at the face becomes Fc(moving) = Fc(static) - VgQ
2. I do not modify the boundary conditions. For example, at a solid wall, I have v = 0 and not v= vg.
3. The grid is non-deforming, and is only translating/rotating with a prescribed motion. Therefore the grid velocity is determined analytically. I recompute the location of the grid points, grid metrics, etc at each physical time step.
Is that correct? I am having an issue when computing the fluxes at the walls. Using the continuity equation as an example, the normal convective flux for a moving grid is
Fcm = rho*(Vn - Vg) (Vn is the contravariant velocity, not relative)
At the wall, I have Vn = 0 in an inviscid case, so that Fcm = -rho*Vg --> This does not work...
If I put Vn = Vg, so that Fcm = 0, then it gives the correct results...
Is there something I have misunderstood?
Thank you very much for your help!
Joachim
Joachim is offline   Reply With Quote
Moving meshes charlotte Main CFD Forum 5 September 19, 2006 08:52
Moving meshes Kraev Stanislaw Main CFD Forum 2 April 11, 2003 14:09
Moving meshes, is that possible Stanislav Kraev Siemens 0 April 8, 2003 12:23
Restarting for problems with moving meshes Maya Siemens 2 October 4, 2002 04:51
Arbitrary Sliding Meshes Anna Siemens 0 September 1, 2002 07:02
