how to read plot3D mesh file (.x)
Old   August 26, 2014, 01:38
Question how to read plot3D mesh file (.x)
Pranav
pranavladkat is on a distinguished road
I need to write a function to read the plot3D mesh file in my code (in C). The mesh file will be 3D and currently single block. Can anybody explain me plot3D file format and how it is written. As a test case, I created a simple flat rectangular surface and exported it in 3D plot3D file format using pointwise. The surface mesh has 5x10x1 dimension. The output of the file is attaced at the end.
I came to know that first line denotes the number of blocks, second line specifies the number of nodes in each direction. But I wanted to know how the coordinates of each point are specified. Are those x's, y's and z's in any particular direction? I need a general outline of how and in which order the coordinates are specified.
It will be really great help.
Thank you
File output:
1
5 10 1
0.000000e+00 0.000000e+00 0.000000e+00 0.000000e+00
0.000000e+00 1.111111e+00 1.111111e+00 1.111111e+00
1.111111e+00 1.111111e+00 2.222222e+00 2.222222e+00
2.222222e+00 2.222222e+00 2.222222e+00 3.333333e+00
3.333333e+00 3.333333e+00 3.333333e+00 3.333333e+00
4.444445e+00 4.444445e+00 4.444445e+00 4.444445e+00
4.444445e+00 5.555555e+00 5.555555e+00 5.555555e+00
5.555555e+00 5.555555e+00 6.666667e+00 6.666667e+00
6.666667e+00 6.666667e+00 6.666667e+00 7.777778e+00
7.777778e+00 7.777778e+00 7.777778e+00 7.777778e+00
8.888889e+00 8.888889e+00 8.888889e+00 8.888889e+00
8.888889e+00 1.000000e+01 1.000000e+01 1.000000e+01
5.000000e+00 3.750000e+00 2.500000e+00 1.250000e+00
0.000000e+00 5.000000e+00 3.750000e+00 2.500000e+00
1.250000e+00 0.000000e+00 5.000000e+00 3.750000e+00
2.500000e+00 1.250000e+00 0.000000e+00 5.000000e+00
3.750000e+00 2.500000e+00 1.250000e+00 0.000000e+00
pranavladkat is offline   Reply With Quote
Old   August 26, 2014, 23:53
agd
agd is on a distinguished road
Can you access
http://www.grc.nasa.gov/WWW/wind/valid/plot3d.html
agd is offline   Reply With Quote
plot3d
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 07:29
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 12:32
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
